Topic: Build 3696 - POI Beat Gridding Off
HutsyPRO InfinityMember since 2014
Thought I was going mad but seems there was an issue with a previous build.
First beat POIs are screwed, to the point that even if you do remove and re-add, they're still off.
Is this a known issue or something I've somehow messed up? Happened immediately after update.
Thanks,
John
geposted Sun 16 Apr 17 @ 6:09 pm
