I have running VJ 8 on my Mac mini. I have a numark mix track 3 Pro controller, which I have just bought. I play video, karaoke and audio. My question is, I have a still shot of my advertising which I have saved on my computer. Is it possible so that when I am just playing audio, the tv screen can default to show my advertising? If so, is it also possible to do the same with a saved slideshow. Many Thanks in advance
geposted Fri 21 Apr 17 @ 5:23 pm
I think the setting you require is called VideoAudioOnlyVisualisation.
geposted Fri 21 Apr 17 @ 5:56 pm
Thanks will have a try
geposted Sun 23 Apr 17 @ 5:49 pm
Hi, you can add a folder with your advertise files, and videos too., then you can activate the slideshow visualization whit the audioonlyvisualization in the options.
Good luck
GK.
Good luck
GK.
geposted Mon 24 Apr 17 @ 4:22 am
Just something that might be useful, you can use this script on a keyboard key or controller button to turn the visualisation on and off. Adion gave me this.
effect_select 'audioonlyvisualisation' 'SlideShow' ? on & effect_select 'audioonlyvisualisation' 'None' : effect_select 'audioonlyvisualisation' 'SlideShow'
geposted Mon 24 Apr 17 @ 7:50 am
You can also use the Telemedia and Televisual plugins. One is in the Visualisations, and the other is in Video Effects.
geposted Mon 24 Apr 17 @ 8:51 pm
