DOES ANYONE HAVE A SKIN FOR THE OTUS?
OR A REVISED MAPPING??
THANKS.
THANKS.
geposted Mon 24 Apr 17 @ 1:50 pm
There's nothing when searching. Not a common controller.
geposted Mon 24 Apr 17 @ 2:13 pm
Having a little look at the unit, it is supposed to come with midi editor software so you can map it yourself to whatever software you want.
geposted Mon 24 Apr 17 @ 2:32 pm
I know only this skin for VDJ :
https://de.virtualdj.com/addons/6220/EKS_-_OTUS.html
The EKS otus is Nativ Supportet in VDJ 8.2 Buildt 3710
Greatings,Dirk
Greatings,Dirk
geposted Mon 24 Apr 17 @ 6:20 pm
The OTUS Skin is written in a very old Skin SDK version, and probably will not work properly in VirtualDJ 8.
geposted Tue 25 Apr 17 @ 12:29 am
thank you.
I will give it a try anyway.
thanks for the response people.
geposted Tue 25 Apr 17 @ 1:51 pm
