I am looking to find a Hotkey function to Auto Fade out to nothing. So i want the song to just fade out to nothing. Like if i am the middle of the song and need to fade it out automatic with out just using the gain or slider, with a hot key . One key click and i t starts to fade the song out auto. Thx in advance
Sorry this is for VDJ 8.2.
geposted Mon 24 Apr 17 @ 6:07 pm
Use the loopOut plugin. https://virtualdj.com/plugins/?addonid=80111, set the length dial to to your desired fade length, set repeats to zero, have the fade button of the fx gui set to on.
Then just call the fx, {the script below inside []'s is optional,.
[deck X ] effect_active "loop Out" [Y]
X can be 1,2,3,4, left, right, active or default, Y is the optional fx slot number
geposted Mon 24 Apr 17 @ 9:18 pm
When I installed this and tried to make it just fade it automatically stops when I click the effect. It doesn't fade at all. How can I fix this? I just want to click it and have it fade for 4 seconds or so.
geposted Mon 23 Oct 17 @ 3:11 am
Your beats number is too low. Turn the beats dial up.
geposted Mon 23 Oct 17 @ 6:07 am
