Topic: Sample length
Hi All ,
When loading a sample , how long can your sample be ? I'm guessing this all depends on compression and rate but in general is there a Time limit ?
I know I could loop it but just curious if theres a limit on the length a sample will play ,
Many Thanks :)
geposted Tue 25 Apr 17 @ 11:27 am
About 6 hours I guess, although you might run into memory problems loading tracks on the decks or loading any other samples at that point.
geposted Tue 25 Apr 17 @ 12:14 pm
