Topic: Cue Button Stops Responding!
Hi guys
So I have been running 8.2 on the latest update and its giving me some issues throughout the night at my resident gig.
The cue button will just randomly stop working and I have to use the jog wheel on my Numark Mixtrack Quad to take the track back to the beginning. I also have another issue where I select to listen to another deck and it just keeps skipping back to another deck that I don't want to hear in my headphones.
seems to be a couple of bugs I thought I would bring to peoples attention.
cheers
geposted Sun 07 May 17 @ 8:45 pm
If it's just one cue button, think both issues could be a button that starts failing and sending irregular midi signals, causing it to sometimes not work and to other times automatically changing the PFL channel
1st one indeed sounds like a hardware fault.
Q: When this happens, is the track playing and CUE doesnt go back to the previous Cue ? Did you notice if by pressing CUE, a temporary CUE white marker was set at the current position ?
For the 2nd issue. its probably due to the Auto-Headphones selection, mostly happens if you scratch/touch the Jogwheel.
You can turn this automation off by setting the AutoHeadphones (from Settings-->OPTIONS tab) to No.
The cue issue isn't hardware it works fine on vdj7. It happens a couple of times a night and the cue button doesn't even light up but if I reload another track again it will start working. its very strange.
thanks for your reply, its great that we can all work together.
When CUE button stops working can you check if SLIP is active?
