Topic: slip backspin not working properly
I've notice in build 3710 which I have that the slip backspin when using it kills the opposite channel regardless if it's one or two. Haven't had this problem since I started updating, with that being said do I need to go back to a lower build or what.
FYI- This is happening with or without a controller
geposted Mon 08 May 17 @ 6:33 pm
Since b3710 is (now) an early release build, and there is a newer early release build out, I would say either move forward to the current early release build (b3731), or go back to the current public build (b3696)
For actual gigs I would use the public build
You can get them all here:
http://www.virtualdj.com/download/build.html
geposted Mon 08 May 17 @ 8:34 pm
thanks
geposted Mon 08 May 17 @ 8:58 pm
