When i have the pitch fader on the table in midi mode the on screen pitch fader does not match my turntables movements.
The onscreen fader will jump up sometimes 2,3 or 4 bpm ahead of what I want. Thus affecting my mix.
I can make a quick video showing this if needed.
Also when I have the turntables set to show the bpm they do not stay on the bpm when moving up or down, instead it switches to a % which is not what I'm trying to see.
And last but not least when changing the pad mode on the turntables it does not reflect on the skin. I'm using SliverSleek 3 if that matters.
Any insight would be nice...
geposted Tue 09 May 17 @ 12:58 am
And another thing,
When I have the brake speed set to the longest and hit the play/start button on my turntable to stop the deck the track does not slow or wind down like it's supposed to.
Instead it just stops instantly while the record is still turning.
Again any insight as to how to fix these problems would be greatly appreciated...
geposted Tue 09 May 17 @ 1:29 am
Indeed the unit needs a mapping update to include Pads and Pads pages. Will review the mapping tomorrow and answer to your other questions as well, since i ll have the unit in front of me.
geposted Tue 09 May 17 @ 4:37 am
As far as the pitch goes it seems like no matter what it follows the anolog signal Instead of the midi signal that's being sent.
geposted Tue 09 May 17 @ 10:51 am
This will explain it better
Clearly something is wrong between what VDJ is seeing from the turntable??
geposted Tue 09 May 17 @ 1:55 pm
