Discussion about Dance Infinite
geposted Tue 09 May 17 @ 4:18 pm
how do you play it without a controller on a mac ?
geposted Tue 09 May 17 @ 8:27 pm
Ah! It seems you have switched to another pane than the Master section in another skin. VDJ seems to remember that.
Easiest solution is to change to another skin, activate the Master section and switch back. I see this is a bug, I will do my best to get rid of this soon.
geposted Wed 10 May 17 @ 8:17 pm
Ok I'll install it agin after the new update and try it out.
geposted Thu 11 May 17 @ 1:08 pm
Hello,
the Skin is good, but can you please ad a Pitch +/-.
I thing its necessary for Dancing Techers.
Thank you
Thank you
geposted Tue 24 Oct 17 @ 11:54 am
+ 1
geposted Tue 24 Oct 17 @ 12:47 pm
Hi Richartz,
I am using a controller with my skin, so I got rid of all buttons that I never use with a mouse/trackpad but only with the controller. The Pitch slider/button is such a thing. Also a Sync button etc is missing because I have it on my controller anyway. Should you use no controller you could still add keyboard shortcuts to set the Pitch.
geposted Sun 17 Dec 17 @ 11:25 pm
