b3734
When using karaoke and deleting a song from the list, all singer info already entered is deleted as well. I'm sure how you can see this as a problem.
Thanks in advance.
Thanks in advance.
geposted Wed 10 May 17 @ 4:04 am
Still present on 3738 Mac and Windows.
geposted Tue 16 May 17 @ 6:02 pm
Sorry cant follow you.
You have a track in the Karaoke List , you entered his name in the Singer field.
Then you delete/remove the track from the list. Where exactly would you want his name/info to be saved/shown, since you have removed the song ?
geposted Tue 16 May 17 @ 6:39 pm
https://drive.google.com/file/d/0B8xNwJTMYYAnV3h2bUdpZERnbDA/view
See if that helps. My original explanation was a little choppy.
geposted Tue 16 May 17 @ 7:43 pm
I see. When deleting one track, it deletes the names of all of your singers, in the list.
geposted Tue 16 May 17 @ 9:37 pm
Correct.
geposted Tue 16 May 17 @ 10:06 pm
it must be a MAC only thing.
I tried v3734 with my PC and everything is good.
geposted Wed 17 May 17 @ 2:07 am
Same on PC.
geposted Wed 17 May 17 @ 2:10 am
I tried default skin with 2 and 4 deck with same result (all good)
dunno if this will help but just to compare.
anyone else wanna chime in with their results ?
geposted Wed 17 May 17 @ 2:27 am
Will check. Gigging now.
geposted Wed 17 May 17 @ 2:31 am
Nothing out of the ordinary there.
geposted Wed 17 May 17 @ 2:54 am
Can't get that to happen here either.
You just delete with the delete key on your keyboard?
geposted Wed 17 May 17 @ 4:52 am
Yes. Never had a problem with 8.1. More than willing to allow remote support if logging is needed.
geposted Wed 17 May 17 @ 4:55 am
You don't have the delete key mapped as browser_remove or something like that?
geposted Wed 17 May 17 @ 5:05 am
I do, but not in those windows. Here is the script:
browser_window 'playlist' ? browser_remove : browser_window 'sidelist' ? browser_remove
Nothing about deleting singers though! Haha.
geposted Wed 17 May 17 @ 5:17 am
The bug appears only with browser_remove, not with the default delete with no keyboard shortcuts defined
geposted Wed 17 May 17 @ 5:23 am
Will it be fixed in a future release?
geposted Wed 17 May 17 @ 5:46 am
Yes of course
geposted Wed 17 May 17 @ 7:18 am
Excellent. I kinda feel a weird sense of pride when I find a bug!
geposted Wed 17 May 17 @ 7:19 am
