Topic: Crossfader curve
I was curious about the crossfader curve option...wanted to know if turning the midi mappable cfader curve on a controller all the way to the right uses the same script values as the option 'Scratch' in the config panel under crossfader. Reason why i am askin is because that option gives me the best crossfader response for scratching and i want to make sure that anytime i turn the knob on any midi crossfader curve on any controller far right; i will be triggering that scratch option's values.
geposted Fri 12 May 17 @ 2:17 am
I think it is depending on the controller. If the controller has a hardware CF it will probably use the CF curve of the controller.
Wel this would certainly be the case for hardware controlled crossfader knobs as no midi signals are sent back to vdj...but was wondering for midi knobs...so i guess my solution would be to map the cfader curve button to "crossfader_curve "scratch" for every controller i may encounter?
Scratch is indeed the same as having the crossfader curve all the way to max.
Just to clarify...u are saying it matches the exact value as the scratch option in the config panel ok????
Yes
Thanks for that clarification.
