Topic: Video Display on OPPOSITE Channel.
Hi There;
Let me try to explain this problem;
When playing a VIDEO file, the Audio sound is going thur the selected Channel, BUT the Video is BEING DISPLAYED on the Opposite Channel
So wherever I have the Crossfader, You EITHER GET ONLY SOUND or VIDEO from the Playing file.
Sure I can have the crossfader in the middle and have the file in synch, BUT can't USE the other Channel.
I tried to change the parameters in the Options Settings, but the problem Still exists.
How can I Fix This Issue.
Thanks in Advance
Jose
geposted Sun 14 May 17 @ 9:08 pm
When I turn on "Link" on the video pane, the video and audio is linked together and outputs work together when using the crossfader.
That has always worked for me
Are there any chances you have crossfader_hamster option enabled ?
Or you use "param_invert & crossfader" on your crossfader mapping ?
Thanks PhantomDeejay. The crossfader_hamster enabled was the Problem. I disabled it (option NO), and now it Works Right.
I have No idea How or When this option was Turned ON (maybe after an Update)..
klausmogensen: Link is On (linked Together)... Thanks.
Again THANKS for your Help.
Jose
Good thinking. I would NEVER have thought of that as the source of the problem :-)
