hey everyone.
i have a pub and i want to know if there is any plugin that will do what i need. i need to broadcast hd video clips and in between to advertise my manu, drinks ext...
does this software have plugins which support the fallowing:
1. i want to broadcast video clips as a playlist like in winamp with shuffle, repeat, automatic crossfade. can i do it?
2. i need to broadcast between the video clips, every now and then (lets say every 10 minutes) a flash/video/presentation like "happy hour" prices, pictures of the manu. can this software do it?
3. can i put some text that will run on the video clips like "no smoking allowed"?
4. can i create scedule for playlists? for example, playlist 1 will play bewtween 13:00 to 18:00 and playlist 2 will play between 18:00 to 2:00?
please help.
thanks
please help.
thanks
geposted Wed 17 May 17 @ 5:28 pm
1. Yes, Automix List provides the ability to set the List in shuffle, repeat and define how the tracks will mix (crossfade)
http://www.virtualdj.com/manuals/virtualdj8/interface/browser/sideview/automix.html
2. Not automatically. You can overlay video or image using Sampler, but you need o do it manually.
http://www.virtualdj.com/manuals/virtualdj8/interface/browser/sideview/sampler.html
3. Yes, you can use the Text Video Plugin. From the VIDEO panel click the arrow button to get the Video Effects list. Then select the Visualizations folder and then on the cog icon next to the Text effect to open the FX GUi and type your message.
4. No
4. No
geposted Wed 17 May 17 @ 6:51 pm
Thank you for the answers.
Im trying to play videos like this:
https://youtu.be/WIXjHt8KmUc
And the picture is jerky and i have k-lite codecs. What should i do?
When im watching 1080p movies thourgh media player classic theres no video problem
geposted Thu 18 May 17 @ 12:24 am
Make sure you run the latest available Build to ensure you have the latest fixes.
What is the specifications of your computer (processor, Ram) and what is your video card model ?
VirtualDJ doesnt use any external codecs, so doesnt matter what you have installed.
Try to see if the videouseDXVA setting (to Yes/No) helps.
geposted Thu 18 May 17 @ 12:28 pm
hi bro's in my virtual dj when record video it's not record perfectly it's hanged what i do give me a link for video plugins
geposted Sat 03 Jun 17 @ 3:05 am
