Topic: Video output problems with latest update
While I am hooked up to Apple TV I constantly get a glitch where virtual DJ stops shuts down and restarts
VDJ8.2 3731
MacBook Pro (Retina, Mid 2012)
2.6 GHz Intel Core i7
8 GB 1600 MHz DDR3
Intel HD Graphics 4000 1024 MB
Yosemite 10.10.5
geposted Sun 21 May 17 @ 3:42 am
Like to add I have no hardware connected just the computer using Apple TV as an output device audio and video. I did check out Apple TV and it works fine by itself
Also I did find out that the latency had switch back to automatic I have to look back through and figure out how to change it again
Just set the latency at 384 is seems to have fixed it. I don't know why my settings aren't staying the way i leave them. i will let you know
if the audio output changed to the apple TV then the latency will default to auto for that device.
OK so what is the problem then why does it keep cutting out and coming back on it's not just the audio it is the whole program shuts down and it comes back on it does pick up where it left off though but it's all my settings change back last Night I ran for about an hour and a half and I did not shut down The only thing I did different was change the latency it did stay at the 384
I do not know how to set a crash report right now I don't see anything in that section is there a code that I need to put in so you guys can see what's happening
Just to let everybody know if you're even looking at this post I did change my latency and it stayed have not had any more problems on Apple TV I will test my other equipment tomorrow and see if I have any issues with it but so far 3 hours of playing on Apple TV and it seems to work fine
