Topic: Video transition location
Hi all,
I have set the setting for random video transitions, but there are only some that I want to use. I understand I need to move the transition files out of the folder in order to make them unavailable for random selection, but I can't seem to find the stock transitions.
I'm on Mac. I looked in Documents/Virtual DJ/Plugins64/VideoTransition and the only file there is the Strips transition that I just recently installed. None of the default transitions appear, like "None," "Additive," "Cloud Dissolve," etc that I want to remove.
Any idea where I can find these?
Thanks!
geposted Mon 22 May 17 @ 1:52 am
Some transitions are native (built in to vdj.exe)
Reread the manual, omitting transitions is done another way, (from inside vdj)
Thanks. For anyone else looking at this thread, the solution is to right click each transition you DON'T want and choose "Ignore."
Interestingly enough, creating an Ignore folder manually and moving them in there has no effect, they still are chosen as random transitions. It must be the VDJ created "Ignore" folder.
