Topic: negative eq movement crackles/garbles
Hi
On a pioneer ddj-t1 the high and low eqs crackle and garble enough to be a problem when only high or low (whilst the 2 other bands are fully off) are used on both deck A and deck B. Swapped and soldered 2 pots from deck D to B as the D pots have barely been used, the problem is the same as before.... have updated to newest build version of vdj, reinstalled both the soundcard and midi mapping from previous use..... not fixed so far.
The eq's were smooth some time ago before updating to a newer version..... today updated to newest build.
geposted Fri 26 May 17 @ 2:32 pm
