With Automix enabled and launching POI Editor with a keyboard shortcut, clicking YES or NO on the POI confirmation window causes a crash. Mac 3572.
geposted Sat 27 May 17 @ 2:22 am
there is no confirmation for POI editor (at least on a PC). I would think its the same on a MAC.
You sure your keyboard shortcut is "edit_poi" ?
geposted Sat 27 May 17 @ 3:50 am
Mapped to "edit_poi." The confirmation windows only appears when pressing escape to close the editor.
geposted Tue 30 May 17 @ 7:38 pm
I would upgrade. v35xx is old.
https://www.virtualdj.com/download/build.html
I tried it again what you and it does not crash or gives me confirmation.
geposted Tue 30 May 17 @ 8:14 pm
Just tried it today with the new version. Same issue.
geposted Tue 30 May 17 @ 8:16 pm
everything is working fine here.
this puzzles me "confirmation window "
there is no confirmation in POI Editor (I'm o n a PC) is this a MAC thing only ?
Someone in here has a MAC. They can check/test for you.
geposted Tue 30 May 17 @ 8:26 pm
geposted Tue 30 May 17 @ 8:28 pm
ok now, I understand what you mean. You wanted to delete a POI.
I thought you meant you went to POI and then you ESC to exit out of it.
Anyway deleting a POI and hitting ESC or answering yes/no, it does not crash. Everything is working as it should for me.
geposted Tue 30 May 17 @ 8:32 pm
That window pops up when I press the escape key. Clicking either button causes the crash.
Weird...
Weird...
geposted Tue 30 May 17 @ 8:34 pm
check if ESC is set to in keyboard mapping....
ESC is defaulted internally "NO" "EXIT" or " CANCEL" etc...
geposted Tue 30 May 17 @ 8:38 pm
It is mapped to highlight the search field for me a la Traktor. It worked in 8.1, then broke in 8.2.
geposted Tue 30 May 17 @ 8:40 pm
I would use a diff key.
Don't use ESC (command is internal in VDJ that could be NO, CANCEL, EXIT etc,...)
geposted Tue 30 May 17 @ 8:42 pm
I don't feel that things should break when upgrading.
Its a small issue that has several workarounds. So I'm not entirely stresses about it.
geposted Tue 30 May 17 @ 8:44 pm
