Topic: Help licenze e 4 decks
Hi, I just bought the license for Virtual 8.2 to use with Hercule DJcontrol AIR, but I did not receive a mail with the number. Also, I would use the skin with 4 decks, is it possible? As? Thank you
Lino
geposted Sat 27 May 17 @ 10:32 am
You won't receive an email with the number - because there is no number.
When you start VDJ 8 it will ask you to log in. This is your registration. When you log in, VDJ will know who you are and apply the correct license.
Perfect, all done...
You could tell me if I can use and how to set the Skin 4 deck .... because I tried but I can not use them separately. Thank you
