Topic: Pioneer DDJ-SP1 Mapping
For some reason my SP1 is playing up.
When I check the controller settings it shows 2 Pioneer DDJ-SP1 units attached when there is just one. It is showing one of these as failed to connect.
If I disconnect the unit, both disappear from setting then both show again, one unable to connect, when I plug it back in.
The unit does not operate correctly when connected. Lots of things wrong so no point in listing them here.
Any ideas?
geposted Mon 29 May 17 @ 10:27 am
Just downloaded VDJ again and re-installed. For now, seems problem over.
