Topic: iTunes Smart Playlists empty
I know I'm referencing the correct xml files on my PC. The normal (drag/drop) playlists have correct data when I view them in VDJ. But the iTunes playlists that are smart (meeting certain criteria) are not showing titles in VDJ. Any suggestions to a fix? Thank you.
geposted Wed 31 May 17 @ 3:38 pm
Odd, I have a ton of them and they all work great. Have you reopened VDJ after the list was finished and iTunes was closed?
More details?
