Hello,
In the last few updates of VirtualDJ, my BeatGrid effect has stopped working. Does anyone know how to fix this?
I'm using VirtualDJ 7.4.7 and Hercules Console RMX.
I checked around the forum and couldn't find any related posts.
I would appreciate any help or guidance!
geposted Wed 07 Jun 17 @ 12:45 am
Does the Effect work if you enable it from the skin ?
Try to delete the Beatgrid..ini file you will find in Plugins/AudioEffects folder and open VirtualDJ again.
geposted Wed 07 Jun 17 @ 8:27 am
Thank you for your response. It looks like I'm missing the beatgrid.ini file in the folder. It looks like all the other affects have both a .ini and .dll file. Could this be the problem? It doesn't work if I enable it from the skin.
geposted Thu 08 Jun 17 @ 11:55 pm
Does anyone else have any ideas?
geposted Mon 03 Jul 17 @ 10:52 pm
We are talking about ver 7, right ? Try this .. https://virtualdj.com/addons/tools.html?category=best&order=default&search=beat
If it doesnt work, delete the Beatgrid.dll from the Audio Effects folder and re-install version 7 (choose to Repair, so that u dont lose any other files, but always a good practice to have a backup at least of your database files)
geposted Tue 04 Jul 17 @ 4:29 am
Thanks so much djdad! The beatgrid repair fixed the issue! :)
geposted Fri 07 Jul 17 @ 1:14 am
