Anyone know the best way to get the Author / Title columns swapped around in the browser window ?
Read some about a Parser DLL, but there doesn't seem to be deatailed info about what it is, how to use it and where to find it.
geposted Mon 20 Oct 03 @ 6:55 am
Hello,
You're right, the parser has nothing to do with the column position.
To permute Author / Title, do this:
1) open regedit
2) go to HKEY_LOCAL_MACHINESOFTWAREVirtualDJ
3) edit the "ColumnOrder" key and put 1 instead of 0
4) launch Virtual DJ
That's all. :)
Please, take care, don't change/delete/modifie anything else in the registery, this could cause windows crash!
1) open regedit
That's all. :)
geposted Mon 20 Oct 03 @ 8:54 am
@Kaleo, "thats just what the doctor ordered", I appreciate U !
How about the column header label, anyway to swap that around too so that it matches the data ? Not a big deal, just wondered... [:o)
geposted Tue 21 Oct 03 @ 6:38 am
That would be a skin adjustment I believe. I think you could go in and edit the text in the xml. I am not a skin master so its just a thought :)
geposted Tue 21 Oct 03 @ 8:05 am
Yes, I discovered that. For anyone else who needs to know, you can swap the column header titles by swapping the values in the Columns section of LANGUAGE.xml like so:
Columns>
CD>Disc
Number>Files
Author>Title
Title>Author
Disc>Disc
Path>Path
Bpm>Bpm
Length>Length
Comment>Comment
Columns>
Also, swap the values in the areas of the Skin's .xml that describes the track info like so:
For Jim Nordic Silver skin:
textzone chan="1">
size width="165" height="13"/>
pos x="64" y="18"/>
text font="tahoma" size="11" weight="bold" color="red" format="%0,0%title"/>
textzone>
textzone chan="1">
size width="250" height="10"/>
pos x="260" y="18"/>
text font="tahoma" size="11" color="red" format="%0,0%author"/>
textzone>
note: tags malformed for the purpose of displaying in the forum.
Mission Accomplished !
3 kinds of people in this world | Those that lead | Those that follow | and Those that say, "how the f$%k did they do that ?
Columns>
CD>Disc
Number>Files
Author>Title
Title>Author
Disc>Disc
Path>Path
Bpm>Bpm
Length>Length
Comment>Comment
Columns>
textzone chan="1">
pos x="64" y="18"/>
textzone>
textzone chan="1">
textzone>
geposted Tue 21 Oct 03 @ 2:25 pm
Hum... I don't think this is a good idea.
You'ld better to use the parser.dll to find the right Author/Title couple, or maybe make a new simple parser that exchange the author/title order.
Neverstheless, it's as you want...
geposted Tue 21 Oct 03 @ 2:40 pm
@Kaleo, why not a good idea ? it seems to work perfectly fine.
geposted Tue 21 Oct 03 @ 2:41 pm
of course, but you have to modifie all new skins you want to use... and for VDJ, title still to be the author and author still to be the title :(
geposted Tue 21 Oct 03 @ 2:44 pm
@kaleo
Well, I don't plan to change to every new skin thats developed. I think there is value in getting used to where to find info in a particular skin.
Anyway this is a great option for me. The good thing is that it's a very simple option for anyone who chooses to do it.
Thanks a bunch for pointing me in the right direction.
geposted Tue 21 Oct 03 @ 2:51 pm
The parser.dll is done for this, so, I will post one to read file like "Title - Authors.mp3" as soon as I will come home today...
If this can help you.
geposted Tue 21 Oct 03 @ 2:59 pm
You can find it now on the download effect page :)
geposted Wed 22 Oct 03 @ 1:25 pm
Thanks Kaleo !!!
geposted Thu 23 Oct 03 @ 5:13 am
You're welcome :)
geposted Thu 23 Oct 03 @ 9:08 am
