djkz wrote :
those extra decks are all normal decks with full functionality.
MrJackson2014 wrote :
For me it's more than enough to handle 4 decks :)
BUT using a few extra decks as samplers, makes me hungry LOL
I often use drumbeats constantly going in the background which I filter and now I can apply FX to certain 'samples' in certain 'groups' split by decks.
EDIT: Is it possible to assign different FX to those extra decks ?
Thid idea runs into the same problem the remix decks did, being able to trigger the decks. To use the decks properly they have to have some sampler type functions. Must be in phase and sync for it to work. Must have loop functions most people won't use complete songs they will use loops. So it must be able to capture loops on the fly, snap in phase. So those things helped the demise of my skin. Only people to do it right is Traktor and Mixvibes.
geposted Tue 27 Jun 17 @ 2:17 am
Done!!
version 1.4 updated, uploaded and waiting for approval.
* Fixed beatbar for deck 11
* Replaced 4 hot cues with 8 pads
* Added crossfader assignment to all 12 decks
for sync to work. just "Beat Lock" and select a "Master deck"
for looping. just set the pads buttons to do loops for that specific deck.
update waiting approval.
here is a preview of the 8 pads
truth be told, the idea is to map your hardware to quickly switch decks [5-12]. set the sampler deck, then switch back to the main decks [3,1,2,4]
to trigger a deck. switch to that deck with your hardware controller, trigger, then switch back. this is a mapping issue
geposted Tue 27 Jun 17 @ 3:14 am
Hello, I already try this skins with videos, working very good, only I have a question. How I can change the number on each side, because this is what I get on this order:
Left: (3) and (1)
(5) and (7)
(6) and (8)
Right : (2) and (4)
(9) and (11)
(10) and (12)
and I will like to get it on this order:
Left: (1) and (3)
(5) and (7)
(9) and (11)
Right: (2) and (4)
(6) and (8)
(10) and (12)
If that posible?
Thanks on advance
Left: (3) and (1)
(5) and (7)
(6) and (8)
Right : (2) and (4)
(9) and (11)
(10) and (12)
Left: (1) and (3)
(5) and (7)
(9) and (11)
Right: (2) and (4)
(6) and (8)
(10) and (12)
If that posible?
Thanks on advance
geposted Wed 28 Jun 17 @ 4:12 am
thank you for the feedback.
it is very much possible and it is also the way it should be.
new version: 1.5 is uploaded and waiting for approval.
it follows the following protocol
3,1,2,4
7,5,6,8
11,9,10,12
3,1,2,4
7,5,6,8
11,9,10,12
geposted Wed 28 Jun 17 @ 5:14 am
Thanks, I hope they approve soon
geposted Thu 29 Jun 17 @ 12:39 am
talk to djdadd.
the problem is i got so excited about it, i submitted 5 updates in 1 day. so there may be delay longer than expected.
the good news.. i'm working on a new skin "Ultra 99" and it's very close to being complete.
visit http://virtualdj.com/forums/218508/VirtualDJ_Skins/New_Skin__Ultra_99.html to see the latest update.
geposted Thu 29 Jun 17 @ 2:56 am
version 1.5 has been approved.
http://virtualdj.com/plugins/index.html?addonid=80619
geposted Tue 04 Jul 17 @ 4:39 pm
can I test the 20 decks?
geposted Wed 05 Jul 17 @ 6:11 pm
djkz wrote :
Done!!
Done!!
Nice feature, but not what I meant. My meaning was every mini deck can be triggered by a pad on the controller. Like pad 1 would trigger deck 3(mini deck 1), Being able to trigger it like a sample.
geposted Wed 05 Jul 17 @ 6:15 pm
djkz wrote :
Done!!
Done!!
watch this video on how to control other decks with the controller.
geposted Wed 05 Jul 17 @ 10:03 pm
