Discussion about Numark Mixtrack Platinum Fix
geposted Mon 03 Jul 17 @ 11:45 am
Hi, I downloaded it and installed it, but nothing changes: I have always humm noise and the LEDs are always dimmed.
What do I have to do after the installation? I see this new file : ''Force Numark mixtrack platinum'' in the Devices folder. How can I use it?
Thank's for your help, Best regards, Christian
geposted Wed 12 Jul 17 @ 8:15 pm
I have a virtualDJ plus license. Should I have a virtual DJ pro license for use custom devices files?
With SeratoDJ I have almost no humm noise, but inactive leds cue/loop pads are off.
geposted Sun 16 Jul 17 @ 9:23 am
Makes sense that when the leds are off there is no humm. As I understand it, it's a bug in the firmware of the unit that the leds cause humm
geposted Sun 16 Jul 17 @ 6:24 pm
Yes exactly, or may be hardware: the power supply of the controller not well filtered
geposted Sun 16 Jul 17 @ 7:44 pm
Yes exactly, or may be hardware: the power supply of the controller not well filtered .. SeratoDJ use less dimmed LEDs. Normally this addon fixes this problem using less dimmed leds, but I can't found the way to use this addon.At this time I use the audio card of the PC: no humm, but I would prefer to use the audio card of the controller ...
geposted Sun 16 Jul 17 @ 8:23 pm
At this time Numark recognized this problem as a hardware fault. It can be repaired under warranty by sending it to their service center.
geposted Fri 08 Sep 17 @ 4:09 pm
That's good news. and thank you for sharing this info.
Kudos to Numark - despite the delay - for acknowledging the problem and offering a solution.
geposted Sat 09 Sep 17 @ 5:33 am
This fix works great , the annoing noise disapear, thanks a lot for this, i preffer Vdj than serato lite :)
geposted Wed 30 Jan 19 @ 10:14 am
ich habe den mixreax platinum fx gedownloaded und ich habe virtual dj pro aber er wird mir nirgends angezeigt bitte helfen sie mir
[script][/script]
[script][/script]
geposted Tue 27 May 25 @ 2:56 pm
You need to post in English here (or use the German area).
Did you not read the description? This download will not be "displayed anywhere" because it's a fix for a hum problem - as stated in the description.
Fixes the humm noise due to dimmed LEDs
geposted Tue 27 May 25 @ 4:53 pm
Hey team, Do i need to install this fix for my Numark Mixtrack Platinum, I do get the error on deck 2 but its random and no idea why i get it, track plays fine and no hum, but surely VDJ updates would of implemented over successive updates maybe?? Query because i dont want to install and create an issue with old Fix thats been fixed, if that makes any sense
geposted Mon 29 Dec 25 @ 11:51 am
Can I get clarification on what this custom map is for? I have a Numark Mixtrack Platinum FX. Is this supposed to be for that or for another model?
geposted Sun 22 Feb 26 @ 7:39 pm
This device offers dimmed leds when Off. However, when many leds are Off (dimmed), there is a humm noise (could be some circuit failure). The "fix" is actually a Mapping definition in which the "Off" state is completely Off for the leds, so eliminates the humm noise.
If for some reason you dont get this humm noise, then this "fix" is not for you.
geposted Sun 22 Feb 26 @ 10:32 pm
