Forum: Addons
Topic: Vocal FX
geposted Fri 21 Jul 17 @ 6:02 pm
It worked at the first time and isn't working any longer. I'm using V8.2, any solution?
probably need to switch to the correct sample pallet then they will work
love it but we need some new ones plz
virtual dj vocals fx is no longer working can you give detailed explaination how to fix this issues. i.e what is pallet ? where to go setting ? ect because this aint working and boy my mixing is not the same i mix bhangra with urban music so the vocals cut out is important to me...and my fans djprecious !
I suggest you use the stems option instead.
how do you get this back... not very [programable savy!!! loved using this with the vocals cut out to get blends sounding better
See post immediately above yours. Vocals can be removed or isolated by using the stems option in VDJ.
