Forum: Addons
Topic: Vocal FX
leneerPRO InfinityModeratorMember since 2014
geposted Fri 21 Jul 17 @ 6:02 pm
It worked at the first time and isn't working any longer. I'm using V8.2, any solution?
geposted Fri 04 May 18 @ 3:28 am
probably need to switch to the correct sample pallet then they will work
geposted Fri 04 May 18 @ 10:10 am
love it but we need some new ones plz
geposted Thu 09 May 19 @ 8:53 pm
virtual dj vocals fx is no longer working can you give detailed explaination how to fix this issues. i.e what is pallet ? where to go setting ? ect because this aint working and boy my mixing is not the same i mix bhangra with urban music so the vocals cut out is important to me...and my fans djprecious !
geposted Wed 19 Jan 22 @ 1:47 am
I suggest you use the stems option instead.
geposted Wed 19 Jan 22 @ 6:00 pm
DWR2001PRO InfinityMember since 2011
how do you get this back... not very [programable savy!!! loved using this with the vocals cut out to get blends sounding better
geposted Wed 13 Jul 22 @ 10:28 pm
See post immediately above yours. Vocals can be removed or isolated by using the stems option in VDJ.
geposted Thu 14 Jul 22 @ 8:34 am
