Topic: Pitch Fader
Hey everyone, not sure if this is the right section but my issue is that I'd like to make my pitch faders on either my program or for my controller (CMD STUDIO4A) less sensitive.
geposted Tue 15 Aug 17 @ 4:27 pm
Well what % are they on now? You know you can change the percentage, yes?
Also, you don't have to use the range provided by default or on the skin. You can set a smaller range in config, like 1 or 2 percent.
