Forum: Wishes and new features
Topic: Third Deck
I love doing live remixes (and my crowd normally like hearing something new/remixed) when I play - so I utilise two decks to play "one virtual song". eg Deck A for beat and Deck B for Vocals (kill bass, etc) - to continue playing it would be good to then have a THIRD DECK rather than use multi-instance or something like that. Please consider an additional deck or choice - MixPro has something like that
geposted Tue 21 Oct 03 @ 12:16 pm
That's really an important feature that many users would like to have. We asked that question already many times but the devellopers are afraid the system requirements are going to be to high. Maybe they have another point of view with the release of Virtual DJ? It would be cool if you could select between 2 or 3 decks (not multiple instance), that's for sure!!!
GnoedeL
I hope support will add a coment after this - but I wonder how much system resource multi-instance uses? Thanks for ur input Gnoedel!
Isn't multi-instance much louder than a third deck. It makes four.
Btw, if the 2 instances could be sync, it'll make it, no?
FRUiT94
It would be great to sync the multiple instances! Maybe one day (HINT! HINT!) it will be possible (WE WANT IT!!!!).
Right VirtualDJ Team???? say yes, please?!
GnoedeL
I think the team is considering the 2nd instance sync. I hope that will come soon.
FRUiT94
I know alot of people that would love this feature... WE NEED TO BE ABLE TO SYNC MORE THAN 2 DECKS....please look at this idea. I reckon you could pull some of those trackor DJs over to VDJ if your software could do this.
I've played a little with the mulit instance. I found that currently its difficult to do stuff with b/c you just have to keep ALT+TAB'ing to the other instance to try making adjustments. It all seemed to play fine... I didn't notice the computer having much trouble with it at all. My free ram dropped down to around 180MB i think (I have 512MB total), so I think that means it could have taken more of a beating.
My laptop specks...
HP 1Ghz Athlon, 512MB PC-133 ram, 30Gig HD, running Windows XP (fully updated), Windows explorer, winamp, and even Norton antivirus (in auto protect mode).
