Maybe I didnt missed this but how about letting us have a choice for the begin and end of a loop
geposted Tue 21 Oct 03 @ 12:21 pm
You can do this, create shortcuts for "loop_in" and "loop_out" actions. That's all :)
geposted Tue 21 Oct 03 @ 12:50 pm
Thanks Kaleo... will try that... thought I may have missed that!
geposted Tue 21 Oct 03 @ 1:17 pm
Try some new skins... :) The default skin does not have this feature... Or define some keyboard-shortcuts.
- Jim
- Jim
geposted Tue 21 Oct 03 @ 9:33 pm
Yes Jim is right: there are good skins with the buttons below...
geposted Wed 22 Oct 03 @ 10:40 pm
when the beatloop is working can u make the song 2 play normally in blacground while the loop is still active ?
geposted Fri 07 Nov 03 @ 12:01 pm
No, if it's on loop mode... it is on loop mode, it isn't playing normaly. Normal isn't it?
Nevertheless, you can use some plug_ins like "overloop" to do this type of effect.
geposted Fri 07 Nov 03 @ 1:09 pm
