Discussion about V8 Motor
geposted Sat 02 Sep 17 @ 9:16 pm
I like the skin had to add some..
geposted Wed 06 Sep 17 @ 8:54 pm
Add some? Looks like you've taken things away!
geposted Wed 06 Sep 17 @ 9:26 pm
downloading...
geposted Sat 07 Oct 17 @ 2:17 am
i really love this skin. im getting a "prime" vibe. its a bit basic though. but if you could add a mixer to it it would be perfect. props!
geposted Sat 21 Oct 17 @ 2:10 pm
I wonder why? :-)
I won't be adding a mixer, because it's a skin for use with a controller - and pretty much every controller these days has a mixer. Strictly speaking, it's already over endowed because it has play, cue and VU meters. :-)
geposted Sat 21 Oct 17 @ 4:09 pm
its great btw. true i use a controller. good work.
geposted Sat 21 Oct 17 @ 4:34 pm
Also you need to consider that because of the design/layout, where would a mixer go?
If you really needed one, you could always add a mixer 'window' that pops open.
geposted Sat 21 Oct 17 @ 4:56 pm
true. just old habits.
geposted Sun 22 Oct 17 @ 8:42 am
Boa primeiramente vim te dar os parabéns acho que foi a primeira vez que eu usei uma skin no virtual DJ que tinha o estilo totalmente diferente é que não foce passada e queria saber se vai ter novas versões dessa skin pq melhorias são sempre bem vindas mais mesmo assim pelo seu trabalho
geposted Tue 19 Jun 18 @ 2:06 am
You should post in English here, but thanks for your comments.
geposted Tue 19 Jun 18 @ 4:40 pm
Hey Hi, i was using some version of this skin for some time, I can't find the same version again for some reason.
The version i was using had more option to edit waveform,
Is there anyway i can get that version.
TIA!
TIA!
geposted Tue 11 Oct 22 @ 8:27 am
