What a great looking entry level controller! Can't wait for it to be compatible with VDJ.
https://youtu.be/7egbc44dhS0
geposted Thu 07 Sep 17 @ 9:54 pm
Yes, and I don't fully get why they brand it as entry level
Of course it doesn't have the full sequencer part, but no other controllers than the DJ-505 and DJ-808 have that
It has trim and filter on each channel
It looks like the jog-wheels are the same as the Roland-505
It looks like the pad section is a real 8-pad pad section (not just 8 buttons for other functions, that is placed so they look like a pad section, like on a lot of entry level controllers)
Only the looping doesn't have dedicated buttons, and the effect sections is a little limited with only one knob
Still, this looks more like a mid-level / semi-pro controller to me...
And at that price level I may just get one to play with :)
geposted Sun 10 Sep 17 @ 10:12 am
They're a bait to get you started with the AIRA line.
geposted Mon 11 Sep 17 @ 1:36 pm
how long until roland 202 is compatible with virtual dj
geposted Thu 07 Dec 17 @ 4:06 am
The company never gives a date for any controller support. They have a lot on their plates, and can't give a time. I personally never buy a controller until support is available. I just bought a DDJ-SR2, and a Numark DJ2GO2. If these companies want to lock their controllers, that's fine by me, I only buy controllers that are supported by the software of my choice. You will have to be patient, just like the rest of us.
geposted Sun 10 Dec 17 @ 8:58 pm
Djdad wrote ETA at the end of the month in another thread
geposted Mon 11 Dec 17 @ 7:19 am
Got the 202 with full serato limited edition to try out serato.. its cool but very buggy.. need to go back to VDJ. 202 is dope tho
Make this happen VDJ! Soon I hope
geposted Wed 13 Dec 17 @ 6:10 pm
End of the month they say
But it looks like you are using a free home license of VDJ. That won't work with a controller
geposted Wed 13 Dec 17 @ 7:59 pm
Yea man.. I had the one month full trial and liked it.
I will probably get the monthly.
Thx for the update. Hope it's true, serato driving me nuts right now haha I'm over here trying to see if I could get the 202 to work on rekordbox next smh if not, might have to upgrade my computer
geposted Thu 14 Dec 17 @ 10:38 pm
Any update on a release date?
geposted Fri 29 Dec 17 @ 10:55 pm
look at top of page i'm afraid thats as good as it gets https://www.virtualdj.com/wiki/VirtualDJ8%20Controllers.html
geposted Fri 29 Dec 17 @ 11:00 pm
I hate when they say "coming soon" and you be waiting like smh ... give us a release date or something. I got projects on hold! Sorry guys, just venting
geposted Fri 02 Feb 18 @ 2:01 pm
Second that ! :-)
Bought mine over a month ago anticipating VDJ support. The serato freebie has long run out and my nice new controller is gathering dust :-( .
Please VDJ ?
I need to mix badly !
Please VDJ ?
geposted Thu 08 Feb 18 @ 2:21 pm
You both (the last 2 posts) need to buy a license for it to work when the mapping is ready
Just making sure that you know this...
geposted Thu 08 Feb 18 @ 3:28 pm
Noted Klaus, Ill be getting a pro license,, though ill take a months subscription first to check if theres no major bugs.
geposted Fri 09 Feb 18 @ 11:25 am
It looks like the DJ-202 and DJ-505 is now supported in the current early access build (b4064):
geposted Sat 10 Feb 18 @ 4:45 pm
Thanks downloading it as we speak.
Download link in case anyone else is looking for it (get early acces build 4064):
https://www.virtualdj.com/download/build.html
geposted Sat 10 Feb 18 @ 7:30 pm
Ah YES! Thanks fellas!
geposted Wed 21 Feb 18 @ 9:26 pm
well my question is virtual dj also going to introduce the picth and time that the roland has
geposted Thu 22 Feb 18 @ 11:55 am
The functionality is already included in VDJ8
Pitch n time is a Serato plugin (not Roland) that mainly handles better time stretching used for pitch and key play
My guess is it's because the one included in Serato by default is of real bad quality
Virtual already have the better time stretching algoritm build in by default
It also already have key/pitch play, for instance using the KEYCUE pad page, and key sync functionality
It's all in the manual
But here is a quick demo showing key/pitch play with hot cue, with smart cue (hot cue in time with the beat) and without cueing (the key changes but the track keeps playing) on the key cue pad page:
On controllers with 8 pads pr deck it will usually be mapped to these pads in some way
geposted Thu 22 Feb 18 @ 12:29 pm
