Forum: Addons
Topic: Numark Party Mix Pro
geposted Tue 19 Sep 17 @ 2:33 pm
The pad mode switching does not work. I cannot switch from Cue to Loop to Sample etc.
geposted Tue 04 Dec 18 @ 3:38 pm
This skin is meant to work with the default mapping of the PartMix Pro, so Pad modes are set only from the Hardware (and the skin follows)
Are you using it with a PartyMix Pro ?
geposted Wed 05 Dec 18 @ 3:49 am
No. I do not have a physical controller. I guess that answers my question.
geposted Wed 08 May 19 @ 4:24 am
Bonjour
J ai un party mix pro depuis Décembre 2019 et mon ordinateur ne le reconnait pas avec la prise USB.
Je ne peux donc pas m en servir.
Pouvez vous m aider?
Merci d avance
geposted Thu 30 Apr 20 @ 5:00 pm
Is there/will there be a skin for Numbark Mixtrack Plaltinum
geposted Fri 02 Dec 22 @ 11:53 am
There are no dedicated controller skins any more.
geposted Fri 02 Dec 22 @ 11:54 am
