Hi all,
wanted to find out if there was a way i could get the echo doppler plugin to always check and match the beat/bpm of the track i am playing so that it can be accurate in its use , instead of having to always open up the fx side panel and click on the 'beat' button before it works in sync with the track it has been applied to. Thanx in advance
geposted Sun 15 Oct 17 @ 1:02 pm
1 Stop shouting, posting all capitals is a great way to get ignored, anywhere online.
2, You could call the effect on and press the button at the same time with script.
I'm away from my machine for a few days but I can get you the script by thursday.
geposted Sun 15 Oct 17 @ 2:23 pm
oops...My Bad. I Didnt know about that(Posting In Capitals). Thanks for the heads-up and thank you for your help, Thursday will be fine.
geposted Sun 15 Oct 17 @ 4:23 pm
I would like this too please. :)
geposted Sun 15 Oct 17 @ 9:17 pm
Hmm simple enough, I just needed to be in front of my machine to see the fx gui
effect_active 'echoDoppler' & effect_button 'echoDoppler' 3
You call the fx (toggle) and at the same time you call the 3rd button of the fx.
geposted Thu 26 Oct 17 @ 6:13 pm
Awesome Man...Thanks a lot for your help..very much appreciated.
geposted Sat 28 Oct 17 @ 11:13 pm
Looks like this script also works as well...Just in case anyone wants to try it...
effect_active 'echoDoppler' & effect_button 3
geposted Thu 21 Jun 18 @ 1:47 pm
Yeah vdj will assume you want to control the button/slider of the fx last called in that script.
I tend to avoid using this when explaining scripts so users can see exactly what's happening.
geposted Thu 21 Jun 18 @ 2:26 pm
Wicked. I was using BEATS push for this but want that to be the half beat.
geposted Mon 02 Dec 19 @ 10:50 pm
echoDoppler effect did not transferred from the VDJ 32 to 64bit . Is there way to get it to work in 64 bit?
geposted Tue 03 Dec 19 @ 1:27 am
Not without a plugin rebuild, which needs the source code.
geposted Tue 03 Dec 19 @ 1:35 am
If everybody chips in, would some one write it and how much?
geposted Tue 03 Dec 19 @ 1:42 am
Script issue help needed
FX1_ON
effect_select 'echodoppler' ? effect_active & effect_button 3 : effect active
Only automatically grabs what seems to be the original BPM, not the current. I do use Beat Push as a method to grab the beat but this involves a quick turning on and off of the FX, so it can grab the current BEAT size.
FX_BEATS_PUSH
effect_select 'echodoppler' ? effect_button 3 : effect_beats 1
I'm trying to write the script to not need to use the Beat grab. An automatic grab when turning on. Currently the full script with the other features reads like this
FX1_ON
holding ? effect_show_gui 1: effect select 'echodoppler' ? effect_active & effect_button 3 : effect_active
Edit: on further inspection, turning the FX off, jumps the Delay ms value to the correct current BPM value, turning the FX on jumps the Delay MS to the tracks original BPM value.
Starting to run out of coffee now too
FX1_ON
FX_BEATS_PUSH
FX1_ON
geposted Tue 03 Dec 19 @ 3:13 am
