Your audioConfig might be wrong, show us a picture
geposted Sat 14 Sep 19 @ 4:52 pm
geposted Sat 14 Sep 19 @ 9:05 pm
try removing the line input :-)
geposted Sat 14 Sep 19 @ 9:21 pm
You probably want this, or the wasapi equivalent.
geposted Sat 14 Sep 19 @ 9:40 pm
That was the original state, and did not work.
I first thought the Hercules could be considered to be input...
geposted Sun 15 Sep 19 @ 7:44 am
I guess that this is indeed what I want.
I assume I need to take some action somewhere to have the Hercules Control Steel added to the "card" section...
I will try to keep on looking for a solution, but thanks for any tips and suggestions.
geposted Sun 15 Sep 19 @ 7:50 am
Yup that would be drivers
https://support.hercules.com/product/djcontrolinstinctp8
geposted Sun 15 Sep 19 @ 8:24 am
The Steel has no audio interface, inputs or outputs, so will not appear in the 'card' section of VDJ.
geposted Sun 15 Sep 19 @ 8:27 am
I noticed that for some reason my drivers were not properly installed.
Because I got no notification during/after install yesterday, I did not pay attention (tunnel vision, as you assume that step is correct)
So just uninstalled it, and installed it again, and it is working now.
Thanks all for the support.
where did I get P8 from? *kicks at floor, falls over*
geposted Sun 15 Sep 19 @ 10:04 am
मुझे नया लाइसेंस बनाना है
geposted Fri 05 Mar 21 @ 2:27 pm
Can get license here:
https://www.virtualdj.com/buy/
geposted Fri 05 Mar 21 @ 2:30 pm
i need Licenses for numark please help me
geposted Sun 25 Jul 21 @ 4:14 pm
I need help with license
geposted Wed 16 Nov 22 @ 6:27 am
https://es.virtualdj.com/buy/index.html
geposted Wed 16 Nov 22 @ 6:24 pm
