Discussion about Pioneer XDJ-RX2
geposted Mon 23 Oct 17 @ 7:23 am
thanks Guys
geposted Mon 23 Oct 17 @ 7:48 pm
no le sirven lo filtros es lo unico.
geposted Wed 25 Oct 17 @ 6:11 am
Este es un mapeador no oficial temporal. Algunas cosas pueden no funcionar
geposted Wed 25 Oct 17 @ 9:16 am
Download link doesn't work??
geposted Tue 07 Nov 17 @ 8:32 am
Works fine here...
Both the Windows one and the Mac one
geposted Tue 07 Nov 17 @ 9:52 am
It's maybe because you have an old Cue license and not a Pro one?
geposted Tue 07 Nov 17 @ 10:03 am
I'm not sure. Did the license expire?
Other links for other controllers seem to work?
geposted Tue 07 Nov 17 @ 10:46 am
esa mierda no se descarga q cagada
geposted Sun 12 Nov 17 @ 3:01 am
Hello
I have download it and opend the file with vdj 8
What is supose too happen ?
I can hear sound from the output of the xdj rx2 but thats it ?
Thanks
Eddy
Thanks
Eddy
geposted Mon 13 Nov 17 @ 4:12 pm
rebbie wrote :
Hello
You're not supposed to "open" the file
You're supposed to double click the installer and let it install the file.
Then your XDJ-RX2 will be able to control VirtualDJ software.
Don't expect everything to work perfectly as this is a TEMPORARY solution until official support gets out (which should happen very soon)
geposted Tue 14 Nov 17 @ 9:57 am
adquiere la versin legal y listo, mientras tanto no podras bajar el mapper
geposted Mon 20 Nov 17 @ 11:18 pm
Mulai
geposted Mon 27 Nov 17 @ 2:01 pm
Dlaczego nie działa funkcja pobierania nie mogę pobrać tego pliku ?
geposted Tue 19 Dec 17 @ 10:44 pm
You need a PRO license to download it
You are currently registered with an LE license
geposted Wed 20 Dec 17 @ 6:47 am
Hi I have the Pioneer XDJ-RX2 and cannot get it to run with Virtual DJ.
I have VirtualDJ Pro V7.4.7
Can someone give me a little guidance?
What are the proper sound settings? etc.
geposted Wed 24 Jan 18 @ 8:09 am
1. I think it will only run with VDJ v8.2
2. It's not fully supported - the screens won't fully work
3. Since it's not fully supported, the mapping isn't included in the software, so you need to download it here:
http://www.virtualdj.com/plugins/index.html?category=other&search=rx2
geposted Wed 24 Jan 18 @ 9:32 am
Do you need a separate license for VirtualDJ 8 PRO Infinity?
I specifically bought VirtualDJ 7 Pro just to use with the XDJ-RX2.
Anyway, the sound works. The sound waveform doesn't move. Videos don't play. Is this because I have the wrong license?
geposted Wed 24 Jan 18 @ 11:07 am
No, it's the same license
In v7 you have a license key.
In v8 you validate you license simply by logging into the software (with the same credentials as you use on this forum)
So try downloading v8 from the download page, and see the difference
The only thing not working (if you have downloaded the mapping) should be parts of the screens on the controller
geposted Wed 24 Jan 18 @ 11:41 am
I have V8 running. Signed in.
If I use my mouse to play the track, the computer interface works fine.
However, the controller does not control the visual interface on my computer.
It acts almost like it downloads the track into the unit and has nothing to do with the computer interface or the v8 software...
I don't know if this would have anything to do with it....but had a heck of a time installing the pioneer driver.
I am running windows 7 home, the driver would not install due to the driver not being verified...i had to disable windows verification to install.
Also, are there any video interfaces that are available for v8?
geposted Wed 24 Jan 18 @ 12:16 pm
