Forum: Addons
Addons comments
Topic: Pioneer DDJ-RZX
geposted Mon 23 Oct 17 @ 10:31 pm
Dans le cadre d'une vidéo de karaoké ou il y a plusieurs piste audio, peut on changer facilement de piste audio et aussi pendant la lecture comme peuvent le faire les lecteurs multimédia actuel?
geposted Wed 25 Oct 17 @ 2:34 pm
Maybe better to post here:
http://www.virtualdj.com/forums/29/French_Forum.html
geposted Wed 25 Oct 17 @ 2:50 pm
Yes, thank you for the mapper, hopefully a full version is in the works for the screens as well... *fingers crossed*
geposted Tue 14 Nov 17 @ 4:11 pm
Thank you very much. Im waiting to hear there is a final version and support for the console RZX.
geposted Fri 17 Nov 17 @ 11:57 am
definatly waiting for the full version as the only thing that holds me from buying the rex is that it doesn't support virtual dj
geposted Thu 23 Nov 17 @ 5:43 am
I DOWNLOADED THE CUSTOM MAPPER FILE. NOW HOW DO I INSTALL OR CONFIG ?
geposted Fri 24 Nov 17 @ 1:50 am
The downloaded file is an installer.
Double click it to install the necessary files.
There's nothing to configure
geposted Mon 27 Nov 17 @ 12:45 pm
DO I NEED TO BE RUNNING WINDOWS 10? I AM RUNNING WINDOWS 7. WHEN I RUN THE INSTALL IT ASKS ME WHAT PROGRAM SHOULD THIS FILE BE OPENED WITH AND I CHOOSE VIRTUAL DJ. NOTHING HAPPENS. WHAT AM I DOING WRONG?
geposted Wed 29 Nov 17 @ 6:34 am
Amazing dj
geposted Wed 29 Nov 17 @ 7:51 am
thanks for all. i cant wait for the oficial vercion
geposted Sat 02 Dec 17 @ 12:33 am
Based on findings in another post, It's IE 11 security refusing to let you download something that can be run
The easiest fix is to use another browser, like Chrome
geposted Sat 02 Dec 17 @ 6:20 am
Yes-at last, cant wait until the screens work for video =]
geposted Fri 22 Dec 17 @ 9:11 pm
Fry UpsPRO InfinityMember since 2017
Thanks a lot! Been waiting for this. I will test it out at my gig tomorrow.
geposted Wed 27 Dec 17 @ 6:16 pm
Update: Tested it out. Worked perfectly. Hopefully the screens will be available at some point, but even as it is, for me it's still better than using Rekordbox DJ.
geposted Fri 29 Dec 17 @ 5:36 pm
So when will the full mapper with the screens working be out????????
geposted Thu 01 Feb 18 @ 10:30 pm
Maybe never.
Pioneer is of course trying to block it for anybody but Pioneer
(I'm not sure this is legal in the EU where I'm from, but nobody has taken Pioneer to court over it yet)
Hopefully Atomix will be able to reverse engineer the blocked screens and support them in VDJ
- but there are no guarantees for success
geposted Fri 02 Feb 18 @ 8:49 am
Grazie dell' ottimo lavoro fatto finora , ci sarà una versione definitiva per ddjrzx? Sto aspettando per prendere una decisione , se tenere o vendere la ddjrzx .Scendere da Virtualdj per passare a Rekordbox non è semplice.
Saluti grazie
geposted Sat 31 Mar 18 @ 1:08 pm
