while mixing and recording music video's at the same time using virtual dj for both virtual dj keeps crashing, this is something i've done in the pass without a problem plenty of times using the same machine. virtualdj send me an update 2 days ago which i install, i also upgrade my harddrive to a ssd 1td which i split up in 3 segment one of which holds the music videos. virtualdj cpu meter was about halfway when mixing and recording at the same time which is normal for me, has anyone experience the samething with the new update?.
geposted Fri 27 Oct 17 @ 1:44 pm
Here you have the changelog and history of all versions: http://www.virtualdj.com/products/virtualdj/changelog.html
Here you have the download section: http://www.virtualdj.com/download/build.html
Just get the previous version that worked, and dont use the early update or any update.
geposted Sun 29 Oct 17 @ 7:19 am
