Hi.
After tried with several config options, I'm not able to set a fixed BPM rate for automix mode. So tracks are sync when mix starts but then, when it finishes and only one deck is playing, BPM rate for the playing track comes back to the original rate automatically. I don't want this because I want to maintain the same BPM for all songs in the playlist (assume all tracks are similar BPMs, i.e: between 135 and 130). So, is this possible?
Thanks.
Thanks.
geposted Sat 18 Nov 17 @ 11:37 am
Hi Zelazon,
Did you figure out a way of doing this? I want to do the same thing, but I see that no-one has answered your question.
Thanks,
Nigel
Thanks,
Nigel
geposted Thu 14 Dec 17 @ 2:38 am
Hi All
How do I to set a fixed bpm for my automix
Thanks
Thanks
geposted Tue 13 Feb 18 @ 6:21 am
Open the automix editor and tell it what to do.
geposted Tue 13 Feb 18 @ 6:43 pm
