VDJ 8 has a huge T.C problem with one deck being T.C active it gives off clicks and pops with the volume closed but another song must be playing on deck 2 to test play a track that has a huge empty space you shouldn't hear anything from deck 1 while deck 2 is PLAYING a silent track
Move platter on deck 1 which is T.C active back and forth you will hear clicks and pops press the hot cue button on deck 1 through your midi control mixer you will hear feedback of clicks and pops remember nothing should be heard but deck 2 silent track do not alter your current setting this will not help don't not reinstall this will not help nor a factory reset this is a issue did the same on vdj v5 it don't give off any feedback or clicks or pops with the same testing
V8 4011
4gb ram
Dual core 2.4
Windows 7
Tempo 2
Scratch 8
Ultra latency on
Akai Mixer
1 Turntable tt500
V8 4011
4gb ram
Dual core 2.4
Windows 7
Tempo 2
Scratch 8
Ultra latency on
Akai Mixer
1 Turntable tt500
geposted Fri 15 Dec 17 @ 6:16 pm
V8 4011
4gb ram
Dual core 2.4
Windows 7
Tempo 2
Scratch 8
Ultra latency on
Akai Mixer
1 Turntable tt500
V8 4011
4gb ram
Dual core 2.4
Windows 7
Tempo 2
Scratch 8
Ultra latency on
Akai Mixer
1 Turntable tt500
Fixed by switching tempo to 0 most noticeable at 3
geposted Sat 16 Dec 17 @ 3:03 am
Most likely your computer just can't keep up then.
You could also try to increase the latency of your sound card.
geposted Sat 16 Dec 17 @ 6:23 am
Yea you would think so what type of specs should I get on a laptop to handle that type of app usage
geposted Sat 16 Dec 17 @ 1:23 pm
http://www.virtualdj.com/wiki/Minimum%20system%20requirements.html
I would shoot higher then what is on that page
i would say at least an i5 processor and 4g to 8g ram
if your doing video as well get the best computer you can afford :-)
geposted Sat 16 Dec 17 @ 1:42 pm
Today retested distortion came back switched the pitch to -1 seem to fix the issue tested 0 with ultra latency on and off still pops was heard changed my buffer from 64-512 still heard pops and clicks pitch
2 gives me feedback of pops and clicks when the timecode is manipulated and hot cue is pressed and volume of decks is off when two songs are mixed got a company event party today so hopefully this stay this way
geposted Sat 16 Dec 17 @ 5:34 pm
Last night happen to have a glitch loading a song with option priority load at low this option seem to cause issues when load at random times
geposted Sun 17 Dec 17 @ 2:42 pm
you could try this to optimize your machine for audio/DJing https://www.virtualdj.com/wiki/PC%20Optimize.html
geposted Sun 17 Dec 17 @ 3:17 pm
For the loading issue I had to switch the load option to Idle normal and low gave off high cpu usage 90-100% which freeze or cause issues in a mix but idle don't even raise the bar 30% this also fixed the clicks and pops this is the progress I'm currently at tempo: 2 scratch: 35 load: Idle
geposted Mon 18 Dec 17 @ 9:08 pm
In VDJ options, just disable the "ultralatency" in the performance tabs and all the pops and clicks disparate !!!
geposted Wed 20 Dec 17 @ 12:43 am
Didn't try it without it on since changing the load option ....always needed it since v5
geposted Wed 20 Dec 17 @ 2:14 am
