Hi.
What is the setting so the cues of the songs can be saved?
Each time i open the program to play i have to find the cues again.
I use windows 10 and vdj 8.2
Controllers pioneer sx2....ergo.
Thanks!!!
Thanks!!!
geposted Sun 24 Dec 17 @ 12:19 pm
I don't think there is any. At least I haven't seen it
Std cues are meant to be temporary. But hot cues gets saved. Back in the days of v7, the temp cue was also saved as hot cue 1. This could mess up hot cues a bit.
But if you like the way that worked, you could change the mapping in v8 to something similar
Here is an example on how you can do it, that I made a while ago
geposted Sun 24 Dec 17 @ 4:07 pm
pretty sure he wants permanent cues :-)
use the hotcue buttons (above platter on ergo, below platter on sx) and set them don't use the "CUE" button by play button.
geposted Sun 24 Dec 17 @ 6:08 pm
now i play as i used to before with vdj7
thanks a lot!!!!!!!!!!
geposted Fri 09 Feb 18 @ 9:34 am
