Topic: Video Memory
I have a Radeon RX 480 Graphics Card
in virtual dj for Video max memory is says Automatic (3064)
does this mean Virtual DJ can't use all 8gb of memory in my video card or is this some 32bit software limitation.
just wanted to clear this up
thanks.
geposted Sat 30 Dec 17 @ 6:08 pm
Depending on the driver it might work to use more, but it's likely that it will actually be worse for performance instead of better.
I also don't think you need more than 3GB cached frames anyway.
geposted Sun 31 Dec 17 @ 7:26 am
thanks for the explanation.
geposted Sun 31 Dec 17 @ 12:32 pm
