when I use ipooldj and load the song im getting a error in playback or a freeze I cant play anything on my paid subscription I tried trobble shooting as a admin same thing
geposted Mon 01 Jan 18 @ 8:15 pm
I am having the same issues, have you received a reply?
geposted Mon 01 Jan 18 @ 9:35 pm
+ 1
geposted Tue 02 Jan 18 @ 3:20 am
I just loaded a track and it just finished playing without issue. It would be helpful if you guys said which build you are using.
geposted Tue 02 Jan 18 @ 3:22 am
3994
geposted Tue 02 Jan 18 @ 3:26 am
You may want to get the early access build, here.
geposted Tue 02 Jan 18 @ 3:45 am
downloaded BUILD 4032 (2017-12-15),
deezer....
deezer....
geposted Tue 02 Jan 18 @ 3:58 am
I've just tested with b4032, and it works ok for me (I'm in Denmark)
Same search:
Two resulting tracks downloaded and playing:
Same search:
geposted Tue 02 Jan 18 @ 11:40 am
I'm getting results from Belgium too.
In your second screenshot it looks like you have some of the audio/karaoke/video filters active, perhaps try to make sure these are de-activated so that all music is shown to be sure it's not related to that.
geposted Tue 02 Jan 18 @ 12:26 pm
i have the same problem on my 3 (mac) machines,i have tried on each machine differnt settings, no luck.......
i have no problem when i use deezer.........
geposted Tue 02 Jan 18 @ 8:55 pm
For me idjpool is working fine on both mac and pc.
geposted Tue 02 Jan 18 @ 9:11 pm
so what is the problem then ?
geposted Tue 02 Jan 18 @ 9:21 pm
Perhaps try to rename your settings.xml in Documents\VirtualDJ and see if it works with clean settings?
geposted Tue 02 Jan 18 @ 9:47 pm
