Topic: Remembering BPM setting
Hi
Is there any way to enable VDJ to remember the BPM setting on a song, so you don't haven't amend it the next time you play it please?
geposted Mon 15 Jan 18 @ 7:47 pm
Tracks are automatically scanned, and you can half or double in the BPM editor.
All changes are automatically saved to the DB, so I'm not sure what you mean here?
geposted Mon 15 Jan 18 @ 7:48 pm
I think he might mean the position of the pitch control (i.e. what he's changed the playback speed to).
geposted Mon 15 Jan 18 @ 8:06 pm
I thought that but there's no reason to do that in DJ software ....
geposted Mon 15 Jan 18 @ 8:08 pm
Yes I mean this some tracks I speed up from 100 to 119bpm for instance
geposted Mon 15 Jan 18 @ 8:38 pm
geemixPRO InfinityMember since 2006
If you really *need* your song to be at the higher bpm every time you play it, why not record it out to a wav/mp3 at the bpm you require and use that version in future?
Or on your first cue, put a comment in to remind you to pitch it up to the bpm etc you require?
Just a thought :)
geposted Tue 16 Jan 18 @ 7:23 pm
Could be done with a POI as well, I think...
geposted Tue 16 Jan 18 @ 7:25 pm
