My head phones crackle when plugged in to my hercules universal controller ,tried u-control audio interface and still having problems will buying controller license fix this ?? HELP ME GUYS!!
geposted Mon 15 Jan 18 @ 9:30 pm
I am pretty sure a different licence will not cure crackles. Have you tried your headphones on a different piece of kit to eliminate them being faulty?
Could be a fault or dirt or a bad connection on tour Hercules device. Or try a different set of headphones to see if that is the source.
geposted Mon 15 Jan 18 @ 11:34 pm
Yeah they work fine mate tried audio interface as well was told it could be because I am running XP but everything else works ok
geposted Tue 16 Jan 18 @ 9:09 am
You will need a controller license (or other license) to use VDJ with a controller for more than 10 min at the time, after the 30 day trial
But I don't think that will fix your issue.
That sounds like you have set your latency lower than your system/hercules driver can handle
geposted Tue 16 Jan 18 @ 9:43 am
Yeah I no that I just don't what do buy it if my head set doesn't work I'm going to try in different computer today
geposted Tue 16 Jan 18 @ 10:09 am
Hi There. I'm new to VDJ 8 but figured this fix out after a week of struggling with the distortion problem. hope it helps you.
![](/img/253450/74401/Heaphone Audio Fix (VDJ 8).jpg)
geposted Fri 19 Jan 18 @ 9:57 pm
If your speakers are connected to your controller, you should remove the first line of the audio config (master to realtek) as it's not necessary.
geposted Sat 20 Jan 18 @ 12:23 am
I know its not neccesarry but for some reason it took away the distortion I had on the headphones. I see there is alot of peeps who is experiencing this problem with headphone distortion where VDJ dont have a clear solution. Hope the next update will sort this out....cause its hell of a frustration.
geposted Sat 20 Jan 18 @ 4:35 am
Damn I spoke too soon. Just checked my setting again and now the distortion is back on the speakers.
I initially thought it was a problem with my PC Laptop or the Mr Dj VDJ 8000 Controller i just bought in the begining of the year. Luckily for me Im not a stranger to DJ software and Controllers as I have been running Mixvibes Cross DJ with a Umix Controle Pro for over 7 years now. I tried the Umix Control Pro with VDJ 8 and the distortion is still there.
Hoping VDJ's developers will work this out pretty soon. At least In have a back-up plan.
geposted Sat 20 Jan 18 @ 5:01 am
Adjust your latency
its been said 2 other times above.
https://www.virtualdj.com/wiki/Sound%20Issues.html
geposted Sat 20 Jan 18 @ 12:34 pm
Hi There Wickedmix. VDJ 8's settings was never the issue.
While VdJ was playing I went into the PC's Control Panel. Went into Sound - Manage Sound Device. Selected the Midi Controllers Headphone and went into its properties. Then I changed the setting from
16bit 48000hz (Dvd Quality) to 16bit 44000hz (CD Qaulity). Distortion on headphone instantly dissapeared.
Now I can finally enjoy VDJ 8...I was seriously contemplating to let it go.
Hope this helps everybody
geposted Sat 20 Jan 18 @ 2:38 pm
