Im new in djing and i have some questions..
I got a numark mixtrack pro2 and a old laptop ..i want to buy a vdj le but im not sure in the case i change laptop if i will continue play with my old lisence or to buy another... please help me..
geposted Sun 21 Jan 18 @ 8:34 am
You can't buy VDJ LE. It's only ever supplied free with new controllers.
If you didn't get LE with your Mixtrack then you'll need to buy a license. If you're only using it at home then you can buy a Plus license that will enable you to use (just) the Mixtrack. If you are gigging with it then you'll need the Pro license or subscription, which will allow you to use any controller.
The license is enabled by logging in to VDJ with your forum username and password, so you can use it on any laptop.
geposted Sun 21 Jan 18 @ 11:01 am
Thank you very much groovindj
geposted Sun 21 Jan 18 @ 4:46 pm
