Topic: bpm
kensmitPRO InfinityMember since 2011
All my music has been scaned and annalized but latley the bps are all changeing songs that use to be 90bpm are now 180 i even see songs in the 200 range . ill put a song on and by the time it loads the bpm has change. Any idea?????
geposted Fri 26 Jan 18 @ 12:29 am
geposted Fri 26 Jan 18 @ 12:50 am
One easy way to gather all tracks above a certain BPM value is to create a Filter Folder with filter : BPM>170
Then if you want to batch edit the BPM of all those songs, select that FF you created, click on one of the tracks of that folder, CTRL+A to select all, right-click->Tag Editor and use the /2 button you will see next to the BPM value.
But we would be interested in tracks that are detected with a very high BPM value, even though they should get half of that. Can you name a couple of such tracks ?
geposted Fri 26 Jan 18 @ 5:12 am
i tried the idea using the /2 and it brought the song to 80 from 160bpm but i have so many songs. ill have to try the filter folder next
geposted Fri 26 Jan 18 @ 9:54 pm
