I just switched computers and now the music that would load and match seamlessly will not sync at all... not one song ... switch back to old computer and no problem. Old one was HP new one is Dell. Any help please !
geposted Mon 29 Jan 18 @ 2:00 pm
Did you copy the files from one computer to the other ?
If you did and saved it at the same place on the drive you should be able to just copy the database.XML file from the first computer to the new one.
You can find it in your documents in the VirtualDJ folder.
geposted Mon 29 Jan 18 @ 3:26 pm
