Does anyone have the mapping for the crossfader and slider volumes for the American Audio VMS5 please?
Even in factory settings the mapping is wrong.
1) The crossfader works on the left deck but not on the right deck.
2) The blue slider controls the red volume and the red slider controls the blue volume. How can I correct this so the blue controls the blue and the red controls the red?
geposted Mon 05 Feb 18 @ 3:32 pm
Can you eventually invert the Crossfader in VDJ Options ?
Manual for the VMS 5:
https://virtualdj.com/manuals/hardware/americanaudio/vms5.html
Have not my Notebook and VMS 2 here for look for this.
Greatings,Dirk
Greatings,Dirk
geposted Mon 05 Feb 18 @ 5:23 pm
There are 2 things that you need to take care when it comes to proper channel/decks mixer controls.
One is the Audio routing, which depends on the channels you have assigned in the audio Setup of VirtualDJ and the other is the VDJ Mixer layout from the options in the 4 decks skin.
Take a look at this page https://virtualdj.com/manuals/hardware/americanaudio/vms5/advanced/midilogs.html
geposted Mon 05 Feb 18 @ 5:27 pm
Mapping for American Audio VMS5.0 hola alguien me puede ayudar tengo una VMS5.0 con virtual dj 8 pero no me funcionan los ecualizadores.
geposted Mon 29 Apr 19 @ 10:02 pm
