Topic: tracks automatically adjusting tempo
Every time I go into virtual dj, i play a track on one deck and then i load one on the other and it changes the bpm to that of the first track. I keep going into auto pitch matching and pitch set on load to change the settings but it won't save, it just reverts back every time i open VDJ. All I want is tracks to play at the actual tempo and not have to change this setting every time I use it, cheers in advance.
geposted Wed 07 Feb 18 @ 5:08 pm
Set it to No.
geposted Wed 07 Feb 18 @ 5:35 pm
That is already set to no. But the problem is the settings don't save. They revert back every time I close it and open it again.
geposted Wed 07 Feb 18 @ 6:52 pm
Then it has to do with Write properties/permissions on the /Documents/VirtualDJ folder
The User (you) doesnt have Admin rights ?
Right-click on the VirtualDJ folder -->Properties
In the General tab, make sure the Read-Only is not checked.
In Security tab, make sure the OS user (you) has Full control
geposted Wed 07 Feb 18 @ 8:18 pm
