Topic: Lost my history
idj4uPRO InfinityMember since 2004
Started VDJ
Updated to the latest version
Restarted program.
VDJ error about the database being corrupt. It fixes itself, I have NO music.
Restart laptop.
Now I have my folders and favourites, but NO MUSIC.
Had to rescan entire drive, and now I have no history, can't sort by most recent plays, or most recent adds.
Also all my cue points etc are gone.
Annoying.
geposted Fri 16 Feb 18 @ 5:32 am
Yes if your database.xml file is gone, the cuepoints, first played, last played, bpm, key and so on is gone
That's why it's important back it up, because a little operating system incident can quickly corrupt such a text file
But the history should still be in playlists in in your /documents/virtualdj/history folder and subfoldes, unless you also lost those, or fully uninstalled VDJ including all files
geposted Fri 16 Feb 18 @ 7:12 am
